left rear brake light and turn signal out
Old Mar 17, 2010 | 09:05 AM
Ndizzle428's Avatar
Default left rear brake light and turn signal out
on my 2007 MC my left turn signal and brake lights are out..i was having a problem witht he fuse blowing on me all the time with it. the fuse is now good and now they are not workin again. the bulbs are good also. every other light on car works fine. not sure what to do..can anyone help? thank you.
Old Mar 17, 2010 | 03:50 PM
Jack The Ripper's Avatar
what up bro, if the bulbs and fuses are good and you've double checked them then it's a wiring issue most likely, you'll have to physically go underneath the dashboard. It's pretty easy to take it off. Anyway take the fuse box cover off first, then unscrew the screws holding the dashboard on and pull the whole thing towards you slightly, be careful though because if you pull it out too much you jack up other wires and theres more headaches for you. So get in there to the wires and just check it out. Hope this helps a little
Old Mar 17, 2010 | 04:07 PM
Ndizzle428's Avatar
alright yea i kinda figured that would be the problem...ill check it out..thanks.
teddyballgame13
Feb 15, 2015 12:36 PM
matthew41
Jan 25, 2015 11:22 AM
hotrodharley
Nov 15, 2013 11:37 AM
heartbeat
Jan 14, 2012 10:47 PM
ricrush
Sep 6, 2007 11:18 AM
