2nd Gen ('73-'77): 1976 Monte Carlo 2bb Rochester Carburetor vacuum line diagram
Hi Guys,
Anyone can help me with vacuum lines diagram? 1976 Monte Carlo 2bb Rochester carburetor.
I also need to know what type of LS Engine swap I can do on this car. I live in CA and it has to be SMOG LEGAL. I am thinking about swapping it with a newer engine and transmission of a 2005 or newer
Thank you in advance
Ok.
There's a line that goes to the EGR, one to the EFE actuator, one to distributor, two lines that go to the temperature sensor in the thermostat housing, two lines that go to the air cleaner, a few "T" connectors…
Is everything original and in tact? If so can you post photos?
Hi Guys,
