2nd Gen ('73-'77): 1976 Monte Carlo 2bb Rochester Carburetor vacuum line diagram
Old Feb 12, 2022 | 09:29 PM
Allnewclassic's Avatar
Default 1976 Monte Carlo 2bb Rochester Carburetor vacuum line diagram
Hi Guys,
Anyone can help me with vacuum lines diagram? 1976 Monte Carlo 2bb Rochester carburetor.
I also need to know what type of LS Engine swap I can do on this car. I live in CA and it has to be SMOG LEGAL. I am thinking about swapping it with a newer engine and transmission of a 2005 or newer
Thank you in advance
Old Feb 14, 2022 | 07:56 AM
zucchi's Avatar
Is this your daily driver?
Old Feb 14, 2022 | 12:52 PM
yes it’s my daily driver
Old Feb 15, 2022 | 08:41 AM
zucchi's Avatar
Ok.
There's a line that goes to the EGR, one to the EFE actuator, one to distributor, two lines that go to the temperature sensor in the thermostat housing, two lines that go to the air cleaner, a few "T" connectors…
Is everything original and in tact? If so can you post photos?
Old Feb 15, 2022 | 12:48 PM
Got it fixed and everything working now. Thank you very much for your help and God bless.
Old Feb 15, 2022 | 01:05 PM
Cool
Originally Posted by Allnewclassic
Hi Guys,
One of us on here could tell you the wrong thing and it might be disastrous not sure if you watch the Motor Trend channel but there is a show call Hot Rod by Lincoln tech they are based in the LA area and they do all kinds of engine swaps they might be able to steer you in the right direction for the smog stuff.
Old Feb 15, 2022 | 02:32 PM
Thank you
tompitomas
Jan 3, 2015 05:29 AM
TSauer09
Jul 31, 2013 12:05 PM
coffeebean
Jun 25, 2012 11:53 AM
polecat702
Dec 11, 2010 08:11 PM
polecat702
Nov 29, 2010 03:53 PM
