14 yr old Code Alarm no sounds HELP Needed !!!
Old Mar 28, 2013 | 10:45 PM
Angry 14 yr old Code Alarm no sounds HELP Needed !!!
I was just informed by the mrs that my "Code Alarm" on the Monte no longer beeps./ No alert tones) Since this Morning..
It still does all its functions, Locks unlocks the doors,open the trunk,and the auto start still works./ with corresponding light indicators(Blinks)
Unfortunately, I have no clue what Model it is...(Code Alarm)
I used it last night... and it worked just fine!
Anyone here proficiant with a 14 yr old Code Alarm system?
I tried to look it up on the net...with no results for my model, year, etc ...
I do know in 1999 it was the latest and the greatest Code Alarm out there!
This is the 1st issue I have ever had with it...In 14 yrs!
Could it be something as simple as the Alert horn is Burned out?
Thanks for looking...
Any advise/Help would be greatly appreciated.
Old Mar 28, 2013 | 11:03 PM
owens91's Avatar
i had this problem when i first got my car. and the simple fix was that my horn fused burnt out, replaced and its been working since...hopefully that might point you in the right direction
Old Mar 29, 2013 | 02:33 AM
Thanks for the suggestion..its not hooked up to the cars horn...
It has its own separate siren/horn...
Old Mar 29, 2013 | 06:35 AM
03SSLE's Avatar
I had a Code Alarm system on one of my vehicles years ago that the siren went bad on. Do you have a speaker you can hook up temporary to test the module?
Old Mar 29, 2013 | 06:43 AM
Thumbs up
Ironically:
I don't... I thru them out last spring when I cleaned out the garage last spring.
But, its good to know..it maybe the horn and not a complete system failure..
andiamo
May 20, 2014 05:10 PM
STUMPMI
Nov 2, 2013 01:48 PM
walkingonabullet
Oct 17, 2012 06:50 PM
Montecarloguy07
Sep 28, 2010 08:30 AM
motivation2k3
Aug 17, 2008 07:50 PM
