Opinion Needed: 07 motor problems? Simple or not?
Hi I have a 07 Monte Carlo SS with the 5.3 stock motor right now. When I bought the car everything seemed fine but a few weeks later everything seemed to go wrong. N no I haven't ragged on it. But the displacement stopped working and there seems to be a bad lifter tick, I'm thinking it's a collapsed lifter. Would you guys suggest tearing it apart n fixing what's wrong or getting a new motor? Also how is the displacement fixed seems like it would be electronically controlled? If I were to upgrade the motor like cold air intake, headers, new cams? What's the best route. Thanks in advanced Jake
Hi `Jake & Welcome to the Monte Carlo Family.
Sorry to read that you are having some issues
with your Monte S.S.
How many miles on your Monte ? How many owners ?
Check back on your thread to see what our member's that may have had the same type of problems/issues with their 06/07 V8. Also, check out our search engine in the top center of each MCF page for topic problems.
Wish you good luck on resolving your Monte problems.
Good Luck
![Frown](https://montecarloforum.com/forum/images/smilies/frown.gif)
Good Luck
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
The lifter tick you are hearing is the DOD lifter, it is a very very common thing in the LS4 motor no need to tear apart the motor for it
Hi I have a 07 Monte Carlo SS with the 5.3 stock motor right now. When I bought the car everything seemed fine but a few weeks later everything seemed to go wrong. N no I haven't ragged on it. But the displacement stopped working and there seems to be a bad lifter tick,Do you have a check engine light on? Do you have a code reader? I'm thinking it's a collapsed lifter. This is a possibility... has happened to many. Would you guys suggest tearing it apart n fixing what's wrong or getting a new motor? There are more than 20 reasons the DoD/AFM has stopped working it is a very sophisticated system.Also how is the displacement fixed seems like it would be electronically controlled? It is electronic, hydraulic, mechanical so first we need to find out the obvious as in CODES in the computer, history of the car example mileage, maintenance done, oil used between changes and type you are using, oil filter you are using and it`s part number. (a lot of times people/places use one filter and the 06 and 07 LS4 use different filters. If I were to upgrade the motor like cold air intake, headers, new cams? What's the best route. Thanks in advanced Jake
For your last question/ questions let`s see if the problem can be found... then go forward from there. One other question how capable are you at fixing, repairing/ overhauling.
Thanks for the quick reply guys. My car has 160,000 on it. N I'm capable of doing an overhaul, I just got done putting new heads n redoing the motor in my beretta GT. But at this current time I'm not looking to sink a whole lot of cash into it yet. Like to fix the tick n get it running right again n work on it during summer.
Not to sure what the DOD lifter is if you could be more specific that would be great.
The displacement is electronical then or?
A DoD lifter is a special 2 stage camshaft/ valve lifter used for the (Displacement on Demand) DoD cylinders only. There are 8 of these lifters in your engine and 8 regular roller lifters. Your engine is a 07 so your system is called AFM (Active Fuel Management)
Does your car still remote start?
So your remote start does not work, that means that your computer/computers are holding codes... WHAT are THESE CODES?
I will ask do you have a scanner?
