7th Gen ('06-'07): 06 Monte SS Traction Control Problem
Old Mar 9, 2013 | 11:02 AM
SSilver's Avatar
Default 06 Monte SS Traction Control Problem
My traction control light has been flashing briefly when I first apply light throttle from a stop...No, the tires are not spinning, but I can hear the traction control system activate briefly as the light comes on.
Important note = I have a Diablew tune on the car that disables the traction control system. I have had this tune for well over a year, but the issue has only been happening for a few months.
I just had new tires installed today, but the same problem is there. Happens at almost every stop/go.
I have also been getting Service Traction Control System and Service Brake System warnings on occasion.
Again, light throttle from a dead stop, no tire spin, traction control light flashes...any ideas?
Old Mar 10, 2013 | 08:07 AM
Possible wheel bearing problems. Do your rims have any play in them
Old Mar 10, 2013 | 12:01 PM
SSilver's Avatar
Wheel bearings were my first thought, so I ordered a set of Timkens last night. This was right after the Service Traction Control and Service Brake Assist warnings came on for the 3rd time in less than 10 miles of driving
I'll let you know if that was the problem...I have to try something, because the issue is getting worse very quickly.
Old Mar 10, 2013 | 12:13 PM
xxtheshockerxx's Avatar
RED DEVIL
my light will randomly flash. no rhyme or reason and if i shut the car off it usually goes right away.
Old Mar 10, 2013 | 12:40 PM
SSilver's Avatar
Mine has quickly gone past "random" to "always". Turning off the car and restarting will clear it, but is certainly not addressing the real problem...
We shall see if the new Timkens do the trick. I would have expected the factory wheel bearings to last more than 37,000 miles...thanks GM.
Old Mar 11, 2013 | 11:10 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
On the driver side of the engine bay, there is an electrical connection that may have come loose. It attaches near the ABS. Mine came loose after a minor accident (head-on into a wall at 70 MPH). After I cleaned the contacts and clicked it back into place, it worked perfectly. Good luck.
chevygirl24
Jan 19, 2021 12:16 AM
TKG2000
Jul 28, 2018 07:38 PM
gburke
Nov 13, 2014 02:11 PM
Jul 8, 2012 08:27 AM
tridski
Jun 26, 2006 09:55 PM
