06 Monte Carlo Heater
Old Oct 31, 2010 | 04:51 PM
Vahighwayman's Avatar
Default 06 Monte Carlo Heater
Dual Zone heater Blower works
Engine warm and NO heat then after a few minutes it may Blow Heat.
It never did this before.
Any Ideas?
Help!
Old Oct 31, 2010 | 06:25 PM
monte07's Avatar
one of three things might be wrong
1. thermostat getting stuck open
2. the dual controlls are worn out not letting the baffels open
3. the actuators that open the heater baffels is needing to be fixed
i would go with the first one replace the thermostat and do a flush and see if that works. then would move to the second the dual heater controlls. then all else fales have the heating system checked as in the aculators that swaps from the heater cor and the a/c condenser. it is usually one of the first two. i will also recomend checking the fuses as well when you do the thermo swap out. to make sure every thing is getting power when you are there under the hood
gdogg090
Jan 31, 2011 03:46 PM
Harleyldraper
Nov 21, 2010 08:12 AM
sunshine1979
Oct 28, 2010 06:50 AM
jdawgkemp
Mar 26, 2009 01:00 AM
ehunni7989
Dec 10, 2008 03:39 PM
