heater question 98' monte carlo
Old Dec 9, 2008 | 07:41 AM
ehunni7989's Avatar
Default heater question 98' monte carlo
i have a 98' monte carlo ls with no heat. the thermostat seems fine, theupper radiator house feels pressurized when up to temp so i know it's closingand theengine temperature looks ok (~190?) according to the gauge. i feel nothing inside but cold air. when i toggle heat-cool driver\passengercontrols it sounds like the flapper is moving although i should mention that the heater mode switch doesn't seem to switch properly to front dash vents, windshield and floor works fine. when i let the car heat up and grab the heater corehoses, the return doesn't even seem warm. this may be a stupid question but is the heater core clogged?? any comments would begreatly appreciated. thx!
Old Dec 9, 2008 | 08:19 AM
Default RE: heater question 98' monte carlo
This is a great question for Chris (scc24540). He has had to repair his heater at least once on his 97 Monte. If I remember correctly, he had a similar problem.
Maybe fire off a PM to him if you don't get an answer by the end of the day.
Old Dec 9, 2008 | 08:27 AM
ehunni7989's Avatar
thanks a lot for the tip- i did actually read his post about his 95' and was wondering if he was able to flush the core out without replacing! i'm gonna give that a shot
Old Dec 9, 2008 | 08:43 AM
ehunni7989's Avatar
should the heater core have flow all the time or is there a control valve that blocks flow to the core when not calling for heat?
Old Dec 10, 2008 | 03:39 PM
ehunni7989's Avatar
i actually got a couple drawing depicting the entire heater\AC unit blend valves etc. dual\single zones. i tried toupload here but apparently 250k jpeg is too large lol... anywayz flushing the heater core worked perfectly! i bought 2ft of 5\8" od poly flow tubing and shoved that into heater core hoses, then flushed carefully both directions using a needle valve in series with the water supply so i didn't over pressurize the core. if anybody has problems and needs these drawings just shoot me a message i would be happy to email them to you...
E
Harleyldraper
Nov 21, 2010 08:12 AM
Vahighwayman
Oct 31, 2010 06:25 PM
sunshine1979
Oct 28, 2010 06:50 AM
bryns96z34
Dec 24, 2009 09:09 AM
jdawgkemp
Mar 26, 2009 01:00 AM
