06 key cylinder install problem
Took out key cylinder to replace my ignition switch now key cylinder wont go back in all the way can some one help with this. repair guide said to turn key to start and depress the tab thru the hole in top of housing and remove did this but like I said now I cant get it go back in all the way.
Maybe this link will have something in it to get you on your way to resolving the problem.
click--->How To Remove/Replace GM Passlock Ignition Key Lock Cylinder Replacement and Relearn/Recode Procedure « AutoRepairInstructions.com I know the list on that site only includes up to 05 but it might be similar enough to get you pointed in the right direction!!![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
As other members read this, someone may have also had this issue and might be able to help.
Oh ok..sorry about that. Hmmm not sure then. I would definately use a light to make sure nothing is loose in there and in the way but I am sure you have already done that.
05montecarloyo
08-08-2012 07:02 PM
