06 key cylinder install problem
Old May 1, 2015 | 08:22 PM
71malibu's Avatar
Default 06 key cylinder install problem
Took out key cylinder to replace my ignition switch now key cylinder wont go back in all the way can some one help with this. repair guide said to turn key to start and depress the tab thru the hole in top of housing and remove did this but like I said now I cant get it go back in all the way.
Old May 1, 2015 | 08:28 PM
Maybe this link will have something in it to get you on your way to resolving the problem.
click--->How To Remove/Replace GM Passlock Ignition Key Lock Cylinder Replacement and Relearn/Recode Procedure « AutoRepairInstructions.com I know the list on that site only includes up to 05 but it might be similar enough to get you pointed in the right direction!!
As other members read this, someone may have also had this issue and might be able to help.
Old May 1, 2015 | 08:33 PM
71malibu's Avatar
Thank you for the link but my problem is the key lock cylinder will not go back into the housing all the way. I did not turn any thing when I removed it so I don't understand why it wont go back in
Old May 1, 2015 | 08:35 PM
71malibu's Avatar
yea the lock cylinder on 06 and 07 are on the column
Old May 1, 2015 | 08:39 PM
Oh ok..sorry about that. Hmmm not sure then. I would definately use a light to make sure nothing is loose in there and in the way but I am sure you have already done that.
Old May 3, 2015 | 09:13 PM
Have you made any progress on getting this solved?
05montecarloyo
Aug 8, 2012 07:02 PM
jeff2425
Dec 9, 2009 07:05 AM
jeff2425
Jul 26, 2008 07:29 PM
2001monte
Jun 11, 2008 08:18 AM
