04 ls will not start
hey guys, new here kinda looked around (at work, cant look to much) but i did not see this. But i just bought an 04 ls (not even 2 months) and last night, i go to get into my car, put the key in, turn it, lights, radio and everything comes on, then i go to start it. Everything turns off, no clicking, nothing..i tried cleaning the starter cables. I only had a wrench, no wire brush, and that didn't seem to work. Any ideas on what it could be besides the starter? i thought i read somewhere that a new key may work, i have 2 others i have yet to try. if its the starter, its the starter..its just that its out in the open at my buddys apt. raining, and i def need my car to get me back and forth to work this weekend. oh yeah, and last week the "security" light on the dash would come on from time to time...sometimes when i start the car, sometimes after i start driving, and sometimes not at all. any help would be appreciated guys. Thank You.
i had tried the new/different key thing, and this worked for about 2 days, and yesterday when i went to start it, nothing. now this morning, i try again...turn the key, lights, radio, dash and everything start working. then i goto start it, everything cuts out and nothing. i do this a couple times and then on the third fourth try, it works, started right up? is this a starter problem or a passlock problem?
Hi StreetBum,
Check out below link & Read Dustybird3 posts, & if it's not
what you need ? Check out the MCF Search Engine.
Got 2 get it runn'in 4 the Dead
https://montecarloforum.com/forum/sh...ad.php?t=13424
click
click
LOL, yall kill me. That's something I'd rather not be a "pro" at, but been there, done that more than once.
I'd almost guarantee it's your Passlock. Time for a new Passlock/ignition cylinder.
Did you happen to notice "security" flashing in your message center? It probably was, I didn't notice it the first time either, LOL. When, not if, it happens again, and it WILL, leave your key turned to "on", the security light will flash (battery, security, security, battery), leave it "on" TEN minutes, not a second less. It will quit flashing (it may still go security, battery, security, battery but not security back to back), then turn "off", then start.
If the security light is coming on when driving, it's telling you it's not working right.
Thanks guys, dusty I didn’t notice it flashing, but it had come on. I haven’t been fortunate enough to be able to try the 10 min deal but we shall see. Also, what would be the most economical way to get this fixed so I don’t have to deal with the hassle?
make shoure your battery has enuff charge to crank the starter. my monte did the same, i left the ignition on and the DRLs drained it enuff so the radio & lights worked but the starter just went clik clik clik clik.... might as well check that B-4 you do the pass key deal
If it's the Passlock, the starter won't click. If it clicks, I'd check for something else.
I had a mechanic friend change mine. You can do it yourself but after seeing half my dash pulled out to get to it, I'm glad we didn't try it. If you do it yourself, be sure to get it tumbled to fit your key or you'll have different keys for door and ignition. Also, you'll have to go through the relearn procedure - do the ten minute thing three times (on ten minutes, off, on ten minutes, off, on ten minutes, off, start)
