04 3.8l LIM gasket removal
Old 09-11-2016, 02:33 AM
Captn_Cook's Avatar
Default 04 3.8l LIM gasket removal
What all should i get for this project?
Old 09-11-2016, 08:31 AM
plumbob's Avatar
Buy the selected items together from Amazon
Felpro MS 98014 T Intake Manifold Gasket $59.32
Dorman 47065HP Elbow Type Heater Hose $9.83
Dorman 615-180 Intake Manifold $70.88 (Only the UIM gasket is req'd, but I recommend replacing the whole thing with this improved Dorman).
ACDelco 131-120 GM Original Equipment 195 Degrees Engine Coolant Thermostat with Gasket $11.47
You'll also need new coolant, motor oil and oil filter. (You need to do an oil change after the repair since coolant leaks into the oil during the repair).
Old 09-11-2016, 08:33 AM
This video may help you out
click-->Repair Guide: Video Tutorial ~ Lower Intake Manifolds R&R
Old 09-11-2016, 11:46 AM
Captn_Cook's Avatar
Thank you for that list plumbob and thank you for that video link p343. Does the video include the torque specs for it?
Old 09-11-2016, 12:29 PM
In the Haynes manual is says
lower intake to cylinder head bolts/nuts132in-lbs
upper intake to to lower bolts/stud 89 in-lbs
If you have the money, the Haynes manual is a very informative resource and can be found at your local parts stores. It has great instructions and pictures for your repair too.
Old 09-12-2016, 08:01 PM
plumbob's Avatar
Note the "inch pounds" in the torque specs. You're gonna' need a torque wrench that reads "inch pounds" not "foot pounds".
Old 09-12-2016, 08:50 PM
Thanks plumbob I meant to point that out. Good thing you said something before he started snapping off bolts!!
Old 09-13-2016, 10:36 AM
turbo monte's Avatar
All info listed above is great info. Only thing I will add is there is a sequence the Lim and uim bolts should be tightened too. I can't remember off top of my head though.
Also I hate felpro so I would suggest all OEM parts. That's just me though, a lot of people use felpro with no issues. Make sure them coolant elbows are the metal ones
Old 09-13-2016, 10:50 AM
When I get home I will try to copy the torque sequence out of the Haynes manual and post it
Old 09-13-2016, 11:36 AM
Captn_Cook's Avatar
Damn..i forgot to order a haynes manual with the parts... it's only $15 at amazon but like $30 at autozone. I'm sure i can find a diagram online though. I received the packages today. The LIM gasket set has me quite confused due to all the extra gaskets that are included. I hope it all makes more sense once the LIM is taken out lol. I also when with the ATP UIM due to all the negative reviews from the dorman one. I also haven't had good luck with dorman parts on my jeep. Had to buy a in/lbs torque wrench too. Had to read what p343 said twice i read I was like "132 ft/lbs"?!?! thats more than the wheels need.
