03 serpentine belt tensioner bracket removal
Does the alternator have to come off to change the serpentine belt tensioner bracket ???? Also, I have read about the coolant elbows, any tips here on not breaking these ?? Any other tips from someone who has done this before ??
03, 3.8
Thanks !!
03, 3.8
Thanks !!
Yes, the alternator will need to come out to remove that bracket (it's bolted to the bracket and will be in your way). As for the plastic elbows, they are about $5 from the autoparts store (look on the DorMan HELP rack). If you have to replace the tensioner, replace that elbow while you are at it (it's common for the elbows to break).
All you need to do is remove the belt, remove the altenator, I believe there are about 3 bolts left (they are hard to see, but you can feel for them and find them easily). Once you think you have them all out, try just wiggling/rocking the assembly, if it moves, odds are you found all the bolts. Just keep gently doing that (once or twice, I gently nudged it by prying with a large screw driver, but be VERY careful, you don't want to force this out, otherwise you may snap the plastic or cast aluminum elbow, and this adds time to the job).
I would say all things go well, it's about a 20 minute job (that's being said as someone "been there, done that"). Allow yourself an hour so you can take your time. Should be not big thing! Good luck!
7th Gen ('06-'07): Serpentine tensioner pully replacement
Hognutsdeluxe
05-26-2014 03:05 PM
matrx10503
12-06-2011 11:11 PM
JaxJim
05-09-2011 09:44 PM
rockin dude
06-12-2010 08:43 AM
