6th Gen ('00-'05): '02 LS 3.4 A/C Question
Old Sep 7, 2013 | 02:41 PM
dns's Avatar
dns
Question '02 LS 3.4 A/C Question
My A/C was working normally and then quit last summer. I've ignored it until now but decided to troubleshoot a little last night. The compressor clutch isn't kicking on when you press the AC button inside with the fan on. So I swapped the ignition/ac relays in the fuse panel under the hood, and it still wouldn't engage. I then jumped point 87 to point 30, and it finally engaged the compressor. But the AC wouldn't blow cold. I also sat inside and held it at a steady 2000 rpm's to try to help it get cold, to no avail. Any ideas/suggestions?
Old Sep 7, 2013 | 02:54 PM
Sounds like it needs a charge, if its low or out of Freon the clutch wont engage.
Old Sep 7, 2013 | 06:21 PM
dns's Avatar
dns
But how would it run low or empty unless it had a leak? Would I be wasting money if I filled it just for it to leak back out?
Old Sep 7, 2013 | 06:36 PM
Its pretty obvious oits low on Freon.... Which means air has gotten into the system.... I would have it professionally filled.... Theres no cold air due to the air pocket in the system..... air in the system = no cold air... The system needs to be vacuumed down (0 air)... and then filled with the proper amounts of oil Freon mix.
Old Sep 7, 2013 | 08:06 PM
Most likely leaked out somewhere, take it to a shop for a servicing and they'll usually put Freon in with a dye in it to try and help locate a leak. Also depends on the size of the leak, it could run for a day, week, month. Who knows.
Old Sep 8, 2013 | 01:36 AM
dns's Avatar
dns
Thumbs up
Ok thanks guys. I'll take it and get it vac'd/filled/checked for leaks. Thanks for the advice!
Old Sep 8, 2013 | 02:50 PM
To add, now that you know the compressor does work, don't force it to run. The system has a way to prevent the compressor from running if it's low on freon.
Odds will probably be that the condenser is bad. But have a professional go over it to be sure. If the condenser is bad, it's an easy change (did it on my Monte this year).
Old Sep 9, 2013 | 01:08 AM
dns's Avatar
dns
Thanks for the tip on the condenser also, maniac. Is there a way to check any of these things without having to pressure test, leak test, or fill it? I'm a pretty good mechanic it's just the only things I have little to no experience with are A/C systems, and the insides of automatic tranny's, lol.
Old Sep 9, 2013 | 05:41 AM
I wish I knew of a way. I had to work with a friend of mine who is a GM mechanic and he injected dye in the system on my Monte. After he found the condenser to be bad, when I changed it, I found a large corner of it covered in "gunk" (for lack of better terms), he suspects that gunk was a result of all the oils in the system blowing out.
