01 monte carlo wont start
Old Jun 14, 2011 | 10:33 AM
anquisia's Avatar
Default 01 monte carlo wont start
car start but shut off in seconds, check engine code it shows is 0171 and 0131. change 02 sensor and maf sensors. it's getting fuel
Old Jun 14, 2011 | 10:47 AM
You can unplug the MAF and start it to see if it is the MAF sensor.
When you try to start the car can you give it gas and keep it alive? That could be the IAC sensor also.
Old Jun 14, 2011 | 11:00 AM
anquisia's Avatar
I can give it gas and it will not hold. Haven't tried to un plug the maf and see if it will crank. But when it was running i unplug the maf and it shut off.
Old Jun 14, 2011 | 11:08 AM
You can try cleaning the MAF sensor (any autoparts store sells a MAF cleaner spray) it is important to use something specifically for the MAF so you don't damage it, also don't touch the sensor wire with ANYTHING, not even a q-tip or blow dryer. Spray it and let it air dry completely before reinstalling.
Also you should check the wiring to your O2 sensor, since that code is displayed when it gets a low voltage reading for 2 minutes. The sensor COULD be bad, but the wiring to the sensor could also be torn.
Old Jun 14, 2011 | 11:48 AM
anquisia's Avatar
I replaced the 02 and maf sensors still getting code 0171 and the car is doing the same thing
Old Jun 14, 2011 | 11:54 AM
Enlight of some of my experiences with those codes (in my case resulting from some mods), the brand of O2 sensor you install could play into it. THe guy I refer to as my GM Guru (he works as a GM mechanic) told me that his BEST experiences with O2s was using AC Delco or Delphi.
He said Bosch, Denso and other after markets may work, but they may not share the longevitiy or may throw different codes (the O2 can be kinda flaky).
schoentges16
Feb 27, 2021 06:43 AM
bigdomvegas
Oct 21, 2017 07:54 PM
BrandonStebing
Jul 25, 2014 11:03 AM
Knightwolf702
May 14, 2014 07:13 PM
Pjw350
Jan 16, 2007 08:29 PM
