01 Monte Carlo SS P0403B , P0404B
Old May 19, 2013 | 04:04 PM
Victory's Avatar
Default 01 Monte Carlo SS P0403B , P0404B
I just replaced the EGR Value due to it going bad, I then got these codes
P0403B - Exhaust Gas recirculation Solenoid Circuit
and
P0404B - Exhaust gas recirculation open position performance.
already tried cleaning EGR port with sea foam deep creep no fix. I unhooked the PCM to check for any damage on the harnesses or the board itself nothing looked burnt or damaged/ bent
2001 Monte Carlo SS 3.8 L V6 LE
Any thoughts as to fixing ? I'm stumped.
thanks,
Vic
Old May 19, 2013 | 10:12 PM
PacerSS's Avatar
Bad EGR I'm guessing. I have a few lying around I could sell you if you want to give that a shot.
Old May 20, 2013 | 10:02 AM
Victory's Avatar
how much we lookin at? I've been told bad PCM due to the circuit code.. A number of things could be effed
Old May 20, 2013 | 10:32 AM
nitehawkjcb's Avatar
So you replaced the EGR, and now you're getting the codes? If so, unplug the battery and let the PCM reset, then see if the codes come back up.
Old May 20, 2013 | 12:16 PM
Victory's Avatar
I replaced the EGR Value, not the hole EGR . I have cleared the codes with a scanner before and they came right back on its a hard fault
Old May 20, 2013 | 01:35 PM
PacerSS's Avatar
Wait, what is an EGR value?
And I dunno, $30 shipped for one sound fair?
Dovas Monte
Feb 1, 2011 01:24 PM
team monte carlo ss
Aug 11, 2008 06:02 PM
