01 Monte Carlo SS - Motor Mounts
Old Jul 20, 2016 | 02:03 PM
spankurmonkey's Avatar
Default 01 Monte Carlo SS - Motor Mounts
So I had my 01 Monte into the GM dealership to have a health check on it before my kid goes off to school next month..... We'll they want 575.00 to replace the motor mounts.
I am wondering how difficult of a job this is?
Old Jul 20, 2016 | 03:27 PM
ohara's Avatar
The upper ones are really easy, the lowers are a bit more intensive. Here are some videos for you to check out to see if you feel you have the tools and confidence to do it.
and here are some links for the poly motor mounts, keep in mind with the poly you will feel the vibration of the motor more than with stock mounts so that is normal if you decide to switch to these ones..
3800 Parts Poly Motor Mounts - Suspension & Brakes
3800 Parts Poly Engine Mount - Suspension & Brakes
3800 Parts Solid Engine Mount - Suspension & Brakes
3800 Parts Poly Trans Mount - Suspension & Brakes
3800 Parts Solid Transmission Mount - Suspension & Brakes
Old Jul 20, 2016 | 03:34 PM
Do you know how many lowers there are?
They didn't tell me exactly which ones were bad.. just that it would be $575
Old Jul 20, 2016 | 07:23 PM
plumbob's Avatar
Just one lower (one the passenger side), but I would also replace the trans. mount (driver side) since you will already have the motor supported and engine cradle lowered. It's also a fluid filled hydraulic mount similar to the lower engine mount.
Old Jul 21, 2016 | 08:19 AM
How difficult are they to replace? I have jack stands and floor jack and if needed my father in law has a lift but not sure if he has anything that would allow us to raise the engine or tranny.
Is it best to replace the uppers too? I looked at the uppers today and they don't seem all that worn but I am not expert.
Old Jul 21, 2016 | 08:29 AM
plumbob's Avatar
Not that bad. Ideally you would have an engine support bar, but you can support the engine from below with a floor jack on the oil pan with a piece of wood between them.
The cradle doesn't have to come all the way out, just lowered most of the way. I unbolted the passenger side completely. Down pipe needs to be disconnected on the exhaust, front engine struts (dog bones) and air intake duct removed. About a three hour job.
Old Jul 21, 2016 | 08:33 AM
Any special tools?
Old Jul 21, 2016 | 08:45 AM
plumbob's Avatar
Nope. Just socket set with a long extension to unfasten the exhaust nuts and open end wrenches.
Old Jul 22, 2016 | 06:36 AM
So I got the motor and transmission mounts. I forgot to ask. How and where did you lift the engine and transmission from and how how do you really have to lift them to swap out the mounts?
Old Jul 22, 2016 | 02:04 PM
plumbob's Avatar
If you're supporting from above attach to the lift brackets. One is beside the alternator, the other at front and center of the valve cover.
Avoid lifting the engine as much as possible. Lower the engine cradle intead. The mounts will drop down with the cradle if you leave them bolted tot he cradle until it's low enough to unbolt from the engine or transmission for them to clear. It's a bit of a trick to wrangle the engine mount around to get it to clear and you might have to roll the engine back a bit. The transmission mount is easier.
