Opinion Needed: 01 monte carlo coolant coming from the front exhaust manifold.
Old Apr 3, 2021 | 05:45 PM
Thomasm32a's Avatar
Default 01 monte carlo coolant coming from the front exhaust manifold.
I am in the process of putting new head gaskets on my 01 monte. it all started when I had coolant blow from between the gasket and the block on the front exhaust manifold, other than the obvious exhaust manifold gasket and more than likely ( or as I assume) head gaskets, any opinions on repairing?
Old Apr 3, 2021 | 11:03 PM
I'm really confused as to how that's even possible. Are you sure the head gasket didn't blow externally and squirt coolant out onto the exhaust manifold?
That exhaust manifold gasket had to have already been toast if coolant came out of it from a blown head gasket. I would just be surprised that it sucked enough coolant to keep that cylinder from firing/ evaporating the coolant but not so much that it hydro locks the engine. Super lucky if that was the case.
No good suggestions from me other than to tear into it and replace all of the top end gaskets.
Old Apr 4, 2021 | 12:22 AM
Thomasm32a's Avatar
Front of old exhaust manifold gasket
Front of old exhaust manifold gasket.
Back of old front exhaust manifold gasket
I'm not entirely sure how it blew like it did but it was definitely a strange thing to see happen. Lol. I appreciate your advice, I'm gonna do as you said and replace the gaskets and hopefully have her back running down the road again. I'll post any progress. Thanks again.
Old Apr 14, 2021 | 06:22 PM
Thomasm32a's Avatar
sorcier11
Feb 24, 2015 06:05 PM
04IntimidatorSS
Aug 14, 2013 05:57 PM
rlopezjr69
Jul 11, 2013 05:52 PM
bat208
Apr 11, 2012 06:05 AM
Shandley
Feb 1, 2012 08:44 PM
