[NEED Help] Edelbrock Carb Install Problem
Old Jan 28, 2013 | 09:40 PM
MySS's Avatar
Default [NEED Help] Edelbrock Carb Install Problem
im putting a edelbrock 600 cfm card on my 85 monte carlo ss. its the stock quadrajet intake i got the adapter for the carb but now my problem is hooking the throttle and kickdown cable to the carb. soooo my question is how do i hook the throttle/kickdown cables to the carb?
thanks
Old Feb 2, 2013 | 11:34 AM
wvmontels's Avatar
Summit and jegs sells all the stuff you'll need to switch your cables over from stock GM to Edelbrock. You'll probably have to buy a bracket for your kickdown and throttle cables to snap into and kickdown and throttle studs to hook the cables to your new carb. Give summit racing or jegs a call and they'll know what all you need to complete your install. If your SS still has the stock 200-4r overdrive tranny keep in mind that your kickdown cable has to be hooked up and adjusted properly for your transmission to upshift and downshift right. Not to mention it will prematurely destroy your tranny if it's out of adjustment or not hooked up. Good luck!
Old Feb 2, 2013 | 09:50 PM
Exclamation
thanks
That edelbrock....Does it look like the old style Carter?
If it does than thats a good carb to run...Its also preset from the factory so you may only need to adjust the idle once you get it mounted and hooked up. throttle/kickdown/fuel.
I cant remember what Choke style your Monte came with...
So, you may end going to a manual choke setup..
I would however recommend getting the matching edelbrock intake for it...
That would make things a lot easier during the instahl... (Eliminates the adapter plate)
Old Feb 5, 2013 | 09:33 AM
MySS's Avatar
Thanks eeveryone for help I ended up getting adapter plate for now...throtle/kickdown cable bracket and a l bracket for the carb that the throttle and kicksown cable attach to...havent started the car yet headers I got for the monte are coming in today
85ssmonte355
Apr 22, 2015 02:44 PM
Skeletal Crow
Dec 22, 2011 08:05 PM
Skeletal Crow
Apr 13, 2011 02:16 PM
wottreng33
Feb 7, 2010 10:21 AM
countryboy07
Dec 29, 2007 11:29 PM
