"Service Traction" Light
Old Oct 3, 2007 | 02:06 AM
lyman's Avatar
Default "Service Traction" Light
My Wife has a 2002 Monte Carlo (3.8L) and the "Service Traction" light comes on now and then. I've searched the web and basically what I've found out is that no one knows why this is happening.
Any ideas?
Thanks,
Lyman
Old Oct 3, 2007 | 10:00 AM
06MCLTZ's Avatar
Default RE: "Service Traction" Light
Best bet would be to go to the dealership and have them look at it.
Old Oct 3, 2007 | 12:41 PM
GrandPaDave's Avatar
When does it happen? Is there a trend?
My service dept. told me there are several TSB's.
Old Oct 4, 2007 | 11:30 AM
HyperFox's Avatar
Hmm.. My guess is its and ABS sensor knocking on deaths door. I would even take a stab at saying its at the front sensors. Most likely a pinched wire from the hub to the harness somewhere. Just a guess tho.
Old Oct 4, 2007 | 10:44 PM
lyman's Avatar
Greetings,
My apologies to everyone for not getting back sooner; the replies are much appreciated!
In conversation with my Wife, 'I' misunderstood her. Right. Anyway, this happened once when she was cutting the wheel while backing into a parking space.
Thanks,
Lyman
Old Oct 5, 2007 | 01:27 AM
04 Intimidator's Avatar
It just might have been a fluke then. Does it still come up?
Old Oct 5, 2007 | 05:18 AM
lyman's Avatar
It hasn't yet. Hopefully it won't again. The vehicle is pushing 100K so we'll see....
Lyman
Old Oct 9, 2007 | 08:41 AM
Mills's Avatar
I've been experiencing the same problem with my 2001 Monte Carlo. Long story short, I had a lot of problems with the traction system trying to engage even when there was no wheel slip. It usually only did it when it was wet outside. It got progressively worse and now the system is completely shut off. Bad thing about it is, it shuts off traction and ABS. I took it to the garage and they told me it was a speed/traction sensor, which is located in the hub, meaning I have to replace the whole thing. Hope this helped you out.
Old Oct 11, 2007 | 06:40 AM
lyman's Avatar
Yes, that does help. Thanks!
Lyman
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
Chevy305
Mar 21, 2011 08:23 PM
04superjr
Mar 21, 2009 12:52 PM
thomasnchy
Jun 5, 2008 08:23 PM
