MCF Website Problems & Issues This area is for problems or suggestions relating specifically to the MCF site, not the car.
LQ1 stucks @3500RPM
Old Apr 11, 2021 | 02:01 AM
rosch64's Avatar
Default LQ1 stucks @3500RPM
Hi Guys´...
as a new member i enter the forum for some questions aboutt my 97´ 5th. Gen MC with the Z34 Option
The problem: The engine "stucks" @3500RPM an wont go higher. You can better seen it at this video:
I had changed many of the sensors to find out, whats going wrong, because my data ( i use the tech2 diagnostic tool) wont give me the answer. Also i have no references what the right data have to be.
Also changed the timing belt. Same result. Sparks are new, cables also...excet the upper O² sensor isnt new, because its hard to get acces to this. Maybe remove the intake...sometimes...
Last idea for me is remove the exhaust ... maybe the catalytic converter is broken...
has any of you experice with the LQ1 & his problems?
let me know...
Old Apr 15, 2021 | 07:53 PM
If the Catalytic converter is plugged it will run doggy for sure.
Also will do that if you have a Vacuum leak. My son had a 97 with the 3.1 engine and it would barley run so I am looking it over and found the Vac hose was disconnected where it goes to the firewall on the drivers side.
You might want to invest in some Genuine GM Service manuals for the car. I will see if I can find a link to get some for you.
Old Apr 16, 2021 | 02:19 AM
rosch64's Avatar
Thanks for Info...yes, that helps... @ the weekend i will look for a leak...i will reporting...
drm3105
Oct 28, 2016 08:53 PM
radd02
Mar 5, 2012 09:35 AM
jshladwig
Dec 5, 2010 12:01 PM
jogasz28
Aug 1, 2006 12:01 AM
jogasz28
Jul 20, 2006 03:28 PM
