Opinion Needed: Factory Amp
Before giving up on the factory amp pull the connectors and spray them (and the receptacles) with some electronic cleaner. My amp began cutting out and cleaning the connectors solved the problem. 2 years and still hasn't missed a note.
If you do need to replace the amp I'd go aftermarket. Keep in mind you will also need to purchase (or make) a bypass harness to take the old amp out of the circuit.
NovaSS369
Sep 11, 2022 09:25 PM
billyjblunt79
Aug 13, 2012 10:23 AM
NovaSS369
Dec 25, 2011 09:44 PM
