MCF Website Problems & Issues This area is for problems or suggestions relating specifically to the MCF site, not the car.
86 4.3 wont run
Old Mar 16, 2020 | 11:13 PM
Montechris's Avatar
Default 86 4.3 wont run
Hello and thanks for helping me in advance. I have an 86 monte with a 4.3, my first car. After sitting for a while I installed a reman long block and replaced numerous components including the fuel tank,pump throttle body,fuel filter. It ran good initially but has since stopped. The pump is working, you can hear it, and the fuel is getting to the throttle body, cracked the fuel line, but it doesn’t spray any fuel through the injectors. If you dump raw fuel into the throttle body it will run. If you pull the wires at the base of the Tbi on the right side and crank motor it reads .5 volts. Again it did run good for a while injectors sprayed as required for a bit and then stopped. Any advice greatly appreciated
Facebook Post
This Facebook post should show the embedded content.
Old Mar 22, 2020 | 02:55 PM
Smile
Back in the 80's I owned an 85 got it with 5K on it when it got to 135K the engine was replaced and seems to me the issue was timing but it has been along time ago now.
Dwayne Pippin
Oct 26, 2014 11:23 PM
84rollin
Mar 23, 2013 04:21 AM
Mattw.2009
Aug 1, 2010 01:27 PM
Gibby
Oct 2, 2008 08:36 PM
Monte Python
Jul 11, 2005 02:56 PM
