wiring amp
Old May 10, 2008 | 03:02 PM
aussiek2000's Avatar
Default wiring amp
Where is a good place to run my power wire through the firewall, and where is a good place to hook up the ground wire? this is a 5th gen monte.
Old May 10, 2008 | 05:44 PM
xxprebunkxx's Avatar
Default RE: wiring amp
I haven't wired any subs into my Monte yet, but if its anything like my Grand Prix, it should be really easy. There should be some holes with plugs in them in the firewall already. Just look underneath and kinda behind the steering column, they should be up there someplace. That's where I ran my power wire anyway, and as far as the ground wire? I just scraped away some paint inside my trunk on the metal and just grounded it to there.
Old May 10, 2008 | 06:00 PM
scc24540's Avatar
you're gonna have to drill a hole, i looked and looked in my 5th gen and found no hole so i made one, and it is a 2 layer firewall so u drill thru 1 piece of metal then into space then into another piece of metal. if u can find a hole then great if not make sure to use a rubber bushing so the wire doesnt run the metal. and as far as ground thats up to you, plenty of metal in the trunk to attach it to just make sure to use a very clean and tight connection
Old May 10, 2008 | 06:03 PM
mickey's Avatar
also can see if you can see a cabel or wires comming threw the fire wall. get a ant. off of the neibors car and push it threw one of the cabels or wires holes int eh fire wall.
then you can tape the amp wire to the end inside the car and pull it back threw the fire wall to the out side and hook it up.
I found a hole in the fire wall and didi this in my 6th gen but itiwas about mid car and way low tot he fire wall.
Old May 11, 2008 | 12:29 AM
couch's Avatar
i found a hole underneath the drivers side carpet that had no wiring coming through it. i'll take a pic tommorow for ya if you like. it looked like a factory drilled hole but i could be wrong.
Old May 11, 2008 | 05:08 AM
It would be great if you could get a picture.
paddock
Apr 23, 2019 11:04 PM
jkeller783
May 1, 2008 11:06 PM
White05LT
Jan 17, 2008 12:05 PM
04MonteSS
Feb 8, 2007 01:44 AM
enigmatic23
Apr 27, 2006 03:30 AM
