Wiring amp
Old Apr 26, 2006 | 08:48 PM
enigmatic23's Avatar
Default Wiring amp
OK, I have a 01 MC Ls and i'm trying to hook up an amp to my factory radio and everything went according to plan until I got to the rem. I have hooked up many systems before but never to the factory radio. I have the converter and thats hooked up to each rear speaker, my ground is connected to the bolt on the rear suspension but I cant find the rem lead. I have 3 blue wires coming off the stock amp and i connected it to the dark blu eone with the black line going through it but nothing. Can anybody help me?
Old Apr 27, 2006 | 01:16 AM
04MonteLS's Avatar
Default RE: Wiring amp
You should not piggyback the remote lead from the factory amp, run the remote from the aftermarket amp directly to your fuse box on the driver side, just make sure to use a circuit that remains powered once the car is turned off and will shut off when the rest of the system does(when you open your door or 10 minutes, whichever happens first.)
Old Apr 27, 2006 | 02:19 AM
Would the power window fuse work?
Old Apr 27, 2006 | 03:30 AM
04MonteLS's Avatar
ORIGINAL: enigmatic23
paddock
Apr 23, 2019 11:04 PM
aussiek2000
May 11, 2008 05:08 AM
jkeller783
May 1, 2008 11:06 PM
White05LT
Jan 17, 2008 12:05 PM
04MonteSS
Feb 8, 2007 01:44 AM
