Winter Project 1: Battery Relocation
Old Nov 21, 2012 | 12:25 AM
01 Monte SS's Avatar
Very nice! Does kind of look like a mini sub box Looks good!
Old Nov 21, 2012 | 04:28 PM
zzapultimate's Avatar
Thanks
Undercoated Sub box
Old Nov 21, 2012 | 06:13 PM
monte06ltz's Avatar
What are you doing with the old spot under the hood?
Old Nov 21, 2012 | 07:06 PM
I'm making a FWI, and the battery is in the way. The FWI will be winter project number 2
Old Nov 21, 2012 | 11:27 PM
monte06ltz's Avatar
I knew when i seen this there was more 2 this post..lol i dont want to make myslef look dumb but whats a FWI if you dont mind me asking
Old Nov 21, 2012 | 11:32 PM
fender well intake = FWI
Old Nov 21, 2012 | 11:39 PM
monte06ltz's Avatar
Thanks
Old Dec 17, 2012 | 11:59 PM
Update time now that school is out for the semester!
Had some time to finish my short battery cables. Inside the box the side terminals hook up to battery and then bolt through the box to the outside where I can attach more wire to.
And since I made this out of particle board, the edges are far from nice. I applied some caulk to the edge I am trying to make a seal. Then when it was partially hardened, I flattened it with some wax paper and the lid. This will provide a smoother edge for some weather stripping to press up against. Some foam weather stripping will go along the perimeter of the lid to make the best seal I can come up with ha :p
Old Dec 18, 2012 | 12:11 AM
Very nice! I really like the terminals
Old Dec 18, 2012 | 03:24 PM
Thanks.. pretty simple
Dropped the battery in for a test fit. I have the main power cable already ran and I hooked up the ground today. I'm using 2 gauge wire. Since I have the power cable all ran I put the box in the trunk about where it will sit and hooked it up to test it. Success! I did notice a slight drop in cranking power. Before, the dome light would dim while cranking. Now with the battery in the trunk, the dome light nearly goes out while cranking. It doesn't seem to have any problems starting the car, but I wonder how it will behave on a colder day or when the battery is not as strong.
Other than that I put a seal around the lid of my box. I'm actually quite impressed with the results. It fits great and seals good
Next I'm going to run wire loom over the power wire to the trunk to make sure it's protected and hidden. I've got a 180 amp circuit breaker coming that I will install on the power line in the trunk as soon as it comes as well.
