Will this work?
Old Feb 22, 2010 | 05:16 PM
Pure2sin's Avatar
Default Will this work?
Any think this would work for attaching the stock positive battery terminal, while attaching rings for amp and HIDs?
http://cgi.ebay.com/SOUND-QUEST-STIN...29853947137201
-OR-
http://cgi.ebay.com/ebaymotors/GM-Si...Q5fAccessories
What I was thinking was add the aftermarket rings to the bottom and screw the adapter into the battery then unscrew the bolt from the top and screw the stock positive terminal into it. That way you wouldn't have to modify the stock positive terminal at all by cutting it. Anyone ever used one of these? Only thing I am worried about is if when the screw from the top is removed if it hole will be long enough for the OEM terminal screw.
Old Feb 22, 2010 | 06:09 PM
Dbl_D718's Avatar
I have the one in your first link. You dont need to do any modifying to the stock terminal, you just pop the stock bolt out of it and put the new terminal in its place. Then you have the top, extra bolt to attach extra ring terminals too.
Be carefull when tightening them down though. They are REALLY easy to over tighten and screw up the threads on the aftermarket terminal.
zipsayain
Mar 4, 2006 03:17 AM
04MonteLS
Sep 12, 2005 01:37 AM
montejass
Jun 30, 2005 07:45 PM
85_Monte_SC
Mar 22, 2005 06:48 PM
dagibbo
Dec 12, 2004 09:51 PM
