Where can I put a amp power cable through???
Old Nov 7, 2011 | 01:48 PM
areed404's Avatar
Default Where can I put a amp power cable through???
So I have a 1997 monte carlo ls, and I'm trying to run an amp power wire through the firewall, but for the life of me cannot find the grommet to put it through! I've already read/scoured threads on here, but none of them really helped. Any help please!!!????
Old Nov 7, 2011 | 02:11 PM
zzapultimate's Avatar
There's a grommet on the drivers side. It's down below the brake fluid reservoir, and comes into the dash above the brake pedal to the left if I remember correctly. I could snap a pic of it quick if you need more help locating it.
Old Nov 7, 2011 | 02:21 PM
areed404's Avatar
thanks tons man! and is it easier to access from the inside of the car or the engine bay?
Old Nov 7, 2011 | 02:31 PM
iMSeRiOuS's Avatar
You could just measure and drill a hole!
I did this on my gf's impala and it works perfect
Old Nov 7, 2011 | 02:53 PM
areed404's Avatar
I think I got it aha. So I'm relatively new to this type of thing so take it easy if I'm wrong lol. So for now I just put a wire through where I believe it to go for, and it went all the way through and out the other end.
Old Nov 7, 2011 | 03:35 PM
You've got it! That's the same one I used. Keep that wire there and use it to help pull your power wire through.
Old Nov 7, 2011 | 10:11 PM
areed404's Avatar
alright thanks man, out of curiosity, what is the hole originally for?
simdog765
Apr 14, 2012 10:50 PM
Killacam
41
Dec 10, 2011 09:17 PM
DJTJ
13
Jun 30, 2011 02:43 PM
monte carlo 3831
Jun 4, 2009 09:36 AM
sumbum06mc
Mar 14, 2008 08:40 PM
