What do you guys think?
This isn't going to be a problem in his situation. Running with a two channel amp with one sub per channel doesn't automatically mean the subs will be playing in stereo. Especially if this headunit has a dedicated sub preamp, it will be a mono signal, which means the subs would be playing in mono in spite of being on two seperate channels.
I run my 75wrms components with a 300wrms amp. Haven't blown them after a year and a half. Buying an amp with lots of headroom can be a good idea if you think you might upgrade later, because with the extra power, you'll have more options for new equipment without needing a new amp too. For example, I bought a 4 channel amp just to run my components in my doors. I did this because I had been considering going active later, so I didn't want to have to buy a new amp if I decided to do that. Until then, it's bridged to two channels giving me LOTS of headroom ![Big Grin](https://montecarloforum.com/forum/images/smilies/biggrin.gif)
It's stable at 2 ohms STEREO, so bridging two 4 ohm subs would result in a 2ohm MONO load, an impedance load that amp is not stable at.
The HU can't decode 5.1 but it does have DSP settings for different sound projections. BTW, the amp was $475 (HD600/4). Whether it was a waste of money or not it's irrelevant to me because I'm vary happy with it's performance.
Distortion that results from under/over powered amps can be AVOIDED by getting the proper amp for the application. It can be tuned out but not completely, IF you raise the signal value to levels that will bring about the distortion.
Buying an amp with "lots" of headroom was the wrong thing to say, but one with 10-15% rms than the speakers it drives is a good idea.
I don't care how much you paid for your amp or if you're happy with it, this thread isn't about you it's about helping the OP so I was pointing out the flaws in your equipment suggestions....
It's obvious that you don't know what you're talking about so rest assured that this discussion isn't a battle of the wills as much as it is me trying desperately to prevent anyone from listening to your shoddy advice.
The only way to over/under power an amp is to either give it too much voltage or not enough. Overpowering it would result in output above it's ratings, underpowering it would result in output below it's ratings.
Power doesn't kill speakers, distortion and clipping does so I don't know what you're talking about when you say "distortion that results from under/over powered amps can be avoided."....I do agree though that 10-15% headroom is good to have in most cases.
It might not be a problem for him, but not for the reason you stated. When the amp gets the signal from the deck, it will sum the left and right signals into one signal, but then the signal gets amplified and split up among however many channels are being run. In this case it would be two, by default it's no longer a mono signal since mono = 1.
How do you know how far to turn the gain down?
Pushing an amp to "it's limits" is nearly impossible since the music we listen to is dynamic, not static. Now if we rolled around listening to test tones all day at full blast, that's one thing, do you do that?
You avoid distortion by adjusting the gain properly, period.
This thread really went bad. 04MonteLS, it seems like you have a decent knowledge base in audio, but some of what you're saying is just not accurate. Plus, the OP isn't looking to spend a whole lot of money and time chasing the perfect sound stage anyway. Why bring up time alignment and 5.1 systems? I mean, seriously, the guy posted up for advice about a budget pair of subs and an amp to power them. No need to freak out about others offering their advice.
He gave some ridiculously shoddy advice and got called on it, I hope nobody takes audio advice from that guy cause it's clear he doesn't know what's up. Just cause you can afford to buy expensive equipment doesn't make your an audio guru. If anybody else care's to continue this conversation, feel free to pm me, but as far as this thread is concerned i'm done with it. My last piece of advice to the OP is to make sure you get an amp that puts out 300 watts rms x 1 @ 2 ohms for those subs. I wouldn't overpower them much, if at all, as they aren't built to handle that.
"You responded "I do, through my head unit." Now you say you don't. There's no confusion on my part, I know your deck can't do 5.1, so my point remains...."
Let me put it in simple terms, My HU has a staging application that allows me to alter the sound to my liking, albeit limited to the 4 choices it provides. I'm also aware that my deck can't do 5.1, I bought it, so your point is irrelevant to what I was trying to say. You are trying to say that my choosing the amp that I got is wrong but I don't care what you think or have to say about my choice. If you would have paid for it, it would be a different story but you didn't. I am well aware what the thread was about, but you had to make it about me criticizing my opinion and choice of equipment, simply stating as fact that a few of members were giving "BAD" advice. My intentions were honorable, but your agenda change that. Sorry my choice and opinion aren't to your liking, bud, but it's mine not yours. Besides, you don't have to agree nor read it, but whatever man!
Mr.Monte
08-31-2012 07:55 PM
jeffsmonte
09-25-2007 08:34 AM
