Voltage drop with aftermarket radio.
Old Dec 15, 2009 | 12:13 AM
bobobeware's Avatar
Default Voltage drop with aftermarket radio.
I recently purchased a 2000 Monte Carlo SS it was equipped with an aftermarket radio (I still have the stock radio connected in the trunk ). Recently I turned on the windshield wipers and the radio at the same time and they both stopped working. Checked the fuses and they are still good but the voltage has dropped to only 3V's. In checking the whole electrical system it seems the installer taped into one of three 12V switched lines because they are all getting only 3V's to them, BCM, Windshield wipers and the Cigarette/ Aux port. Bad Ground? Fusible link? Any help or ideas would be greatly appreciated.
Old Dec 18, 2009 | 01:04 AM
seawolf18's Avatar
If it was a bad fuseable link, you would have no power at all. Check the ground and make sure its clean and tight. Also, try taking the hack-job wiring off, and see if the voltage comes back up.
Old Dec 18, 2009 | 03:12 PM
bobobeware's Avatar
It turned out to be the ignition switch which apparently goes bad sometimes in these cars. Replaced the ignition switch and all was fixed. Thanks for the help
hank635
Jun 14, 2010 02:30 PM
Jordanshedd5
Mar 8, 2010 03:23 PM
bobobeware
Dec 17, 2009 03:06 AM
Frosty LS1
Jul 17, 2009 08:24 PM
labnjab
Jul 5, 2009 07:23 AM
