Twin voltage gauge
Old Mar 1, 2010 | 12:14 PM
Jordanshedd5's Avatar
Default Twin voltage gauge
Im looking for a voltage gauge for the '00 LS, i have a second battery in the trunk. i wmant to be able to monitor both from one gauge, but i cant seem to find anyone who sells a single gauge that can geve voltage readings from 2 batteries. i dont want two gauges, one for each battery, that takes up too much room. Anyone heard of a gauge like this?
Old Mar 1, 2010 | 12:38 PM
kweef's Avatar
cant say i have...
Old Mar 1, 2010 | 12:40 PM
Dbl_D718's Avatar
You shouldn't really need to monitor them seperately unless you're going to isolate them and run them independently; like running the stereo off of only the battery in the trunk while the car is off. Otherwise, they'll both read what the car's system voltage is, so one gauge is enough.
Old Mar 1, 2010 | 05:49 PM
The batteries are isolated, one for starting and engine electrical the other for the sound system.
Old Mar 8, 2010 | 03:23 PM
JaxJim's Avatar
If you or someone you know has some electrical knowledge, you may be able to wire up a switch to any volt meter. You could then use the switch to toggle back and forth between the two batteries using one gauge. There's also a product called a batterybug that attaches to your battery. You can't monitor it from inside the car, but it gives you readouts of the battery health/volts etc http://www.amazon.com/Argus-BB-SBM12.../dp/B000NV7OBE
hank635
Jun 14, 2010 02:30 PM
bobobeware
Dec 18, 2009 03:12 PM
bobobeware
Dec 17, 2009 03:06 AM
Frosty LS1
Jul 17, 2009 08:24 PM
labnjab
Jul 5, 2009 07:23 AM
