Switched 12v Source for Remote Wire?
Old Oct 5, 2009 | 02:32 PM
TTT_Travis's Avatar
I didn't know there was any switched fuses. On the Ford installs I have done I could usually get switched power off certain fuses. On the Monte I tried the power windows and heated seat fuses but none of them seemed to give switched power.
Let me know which fuse(s) are switched and I'll give that a shot or tap into the wire behind the stock deck as a last resort.
Thanks,
Travis
Old Oct 5, 2009 | 02:57 PM
drewskie043's Avatar
i agree with aussiek2000. i would simply get a fuse tap and a test light/volt meter and start checking all the fuses in the interior fuse panel on the lower passenger door area. once you find the one that's switched B+ make your connection with the fuse tap and your done.
i used this method with my foglights. i just used a fuse tap into the low beam headlights so they only come on when the low beams come on. took me less than 10 mins to figure it out...
Old Oct 5, 2009 | 06:59 PM
aussiek2000's Avatar
I know for a fact the wiper circuit on my 04 LS is switched. Comes on in the accessory position. 25 amp fuse in the driver side fuse box inside the car.
Old Oct 5, 2009 | 11:23 PM
MonteDriver's Avatar
i just know for a fact i tapped into the switched on my factory deck and the interface works perfect so it was a better option then running a wire for it.
Old Oct 7, 2009 | 10:37 PM
04MonteLS's Avatar
Thanks,
Travis
Sorry bro, forgot about this thread.......
All you gotta do is run a wire from the "PCM" fuse in the fuse box on the driver side. No need to pull apart the dash and pull the deck out in order to run a remote lead. I ran my system in the same manner for 4 years with no problems whatsoever.
Murray137
Oct 20, 2012 08:13 PM
Josh_NGR
Mar 21, 2012 08:56 PM
RickCoMatic
Oct 1, 2008 01:36 PM
RickCoMatic
May 11, 2008 10:24 PM
God_Bot
Apr 5, 2008 07:38 PM
