Speakers!?!?!?!?!
Old May 11, 2008 | 09:48 PM
zwc0442's Avatar
Default RE: Speakers!?!?!?!?!
Most decks are 50 watts x 4 but that is 50 wattspeak and somewhere around 22 watts rms. I had a set of boston sl95 6x9'srunning off of the deck power on my pioneer 8600 and they sounded decent. But they really come to life when i put a 70 watt x 2 amp in. The amp is rated at 70 watts rms 140 peak per channel. It sounded like i put a sub in compared to before the amp. The deck is probably fine to run factory speakers but to get the most out of a set of good aftermarket speakers you should really use an amp. The difference is like night and day.
Old May 11, 2008 | 11:53 PM
04MonteLS's Avatar
ORIGINAL: zwc0442
True, aftermarket speakers will sound alot better when pushed with an amp compared to being run off a deck. But it all depends on the sensitivity/power handling/efficiency of the speaker and the power/tuning abilities of the deck. Not so much as to IF there will be a difference, more along the lines of how much of a difference there'll be.
victoryred05
Dec 20, 2005 11:40 PM
eric618
20
Aug 24, 2005 06:00 PM
eric618
Aug 22, 2005 05:23 PM
04MonteLS
Aug 13, 2005 03:14 AM
earthquake
Jan 14, 2005 06:20 PM
