Smoke coming from sub box?
Old Jun 5, 2011 | 04:18 PM
Boxman420's Avatar
also on a side note. my sub works on VERY low volumes. but when it gets turned up it works for a second. then it just stops..
Old Jun 5, 2011 | 05:29 PM
bama_z34's Avatar
i would take them amp apart and look at EVERY thing inside it. sounds like something got crossed inside the amp. as for your sub...idk on that one. ive never had one do that.
Old Jun 5, 2011 | 06:27 PM
Boxman420's Avatar
im a little afraid to take the amp apart. mostly because i dont know what to look for. and i dont know how it could just randomly get screwed up while its in my trunk
Old Jun 5, 2011 | 08:52 PM
iMSeRiOuS's Avatar
Originally Posted by Boxman420
i disconnected my amp now. i dont think its blown. but im gonna check other wise im gonna be pissed cause i just bought this amp last week for 200$. i do have a DMM and i used it on each sets of terminals and one read 1.0 and the other read 1.2 OHMs
So your subs are wired up to 1 ohm... from the other posts, it sounds to me that your subs shouldn't be wired to 1 ohm so....
So I think the wiring is wrong.. and I'm afraid that the subs voice coils are possibly burnt (considering the smoke) I'd be worried that subs would burn out the amp but I got my fingers crossed for u
Questions to ask:
What gauge wire are you running inside and out of the sub box?
What are your subs rated at RMS?
(Should be something like 1000watts RMS @ 1ohm // 750watts RMS at 4ohms) something similar...
Then what is your amp's RMS... and is your amp is stable @ 1 ohm? (should tell u in the book for the amp)
Is it a mono amp? (just because it has 4 terminals on the amp doesn't mean it isn't a mono amp!)
SO next step is to re-wire everything... double check it and try again
Old Jun 5, 2011 | 09:00 PM
Boxman420's Avatar
when i used that DMM on the terminals NO wires where hooked up at the time. when they are hooked up one reads .3 and the other reads .7 which in turn makes 1ohm? well i took the amp out for now with hopes its not blown. it still turns on and it doesnt smell or anything so i think its okay. my sub is 300RMS/900peak, amp is 500rms/1000peak at 2ohms it is also a mono amp. the speaker wire for the sub is all 14 guage.
i have watched so many videos and read alot of forums on wiring a DVC 4ohm sub to 2ohms. i wired my sub (+) to (+) and (-) to (-) and then used the outer terminals (+) and (-) to run to the amp. what did i do wrong here?
Old Jun 5, 2011 | 11:43 PM
bama_z34's Avatar
dont be scared to take it apart. ive taken mine apart so many times just to practice. just remember where each screw came from. and if you dont know what to look for just look for places that have a charred/burnt look to them.
Old Jun 6, 2011 | 12:02 AM
milrlyt's Avatar
Were the gains set too high when you first broke them in or something? It really just sounds like you fried something, again, likely a voice coil... Or, hell, sometimes you just get bad equipment and there's nothing you can do to prevent a disaster.
Old Jun 6, 2011 | 07:35 AM
like people are saying, if it's smoke coming from inside the box, the voice coils are burning up.
Old Jun 6, 2011 | 08:20 AM
Boxman420's Avatar
yeah i know i blew a voice coil.. i just dont know why. i was bumping pretty hard this past week. it was probably being over worked. the gain was set a little more then half.
Old Jun 6, 2011 | 09:47 AM
coolfonz's Avatar
I'dtake that puppy back if its doing that after 1 week.
