Running main power lead.???
Old Jun 21, 2008 | 12:55 PM
paddock's Avatar
Default Running main power lead.???
Where in the firewall did you guys go through to run your main power wire for your aftermarket stereo amplifiers in the trunk? I was thinking drilling through by the main wire harness in the passenger side by the floor going up to the firewall? Would that work?
Any input much appreciated! I just don't want to screw this up! lol
Old Jun 21, 2008 | 01:23 PM
scc24540's Avatar
Default RE: Running main power lead.???
i had to drill, i drilled on the drivers side about 5" below and 3" to the right (as your on the front of the car looking at it) the master cylinder. just make sure to put a grommet on the hole you make or eventually it'll wear down to the bare wire and screw everything up
Old Jun 21, 2008 | 04:09 PM
mickey's Avatar
on the 6th gens i did mine threw the fire wall in about the center and it came threw about where the floor dips for the pass. foot well
Also you dont have to drill it to make it go threw there. go ot the person you love to hate the most and steal thier anttna off thier car. Just make sure it is one with the ball on top. this allows it to push threw the rubber on the fire wall and also when you tape the wire to it you cna push it or pull it threw there with out losing it.
Old Jun 21, 2008 | 08:00 PM
paddock's Avatar
ORIGINAL: mickey
Mine's an 02.. you talkin that big *** rubber grommet in the middle of the engine side firewall? I was lookin at that, but I'm not sure if I can shove a 0-gauge wire thru there or not!! Sounds worth a try tho!
Old Jun 23, 2008 | 02:19 AM
mickey's Avatar
yep tha tbe the one. and you cna get one threw there i have "0" guage power leads on mine.
like i said ya need a good strong ant. from the neibors car LOL
i had to tape mine once and it came off so i cheated soem i used a small Zip Tie and then taped over that so it could not hang up on stuff.
Old Jun 23, 2008 | 07:02 PM
paddock's Avatar
I'm intrigued!!!
I'm gonna find sumtin to shove that wire thru tomorrow come hell or high water!!
thanx bro!
Old Jun 24, 2008 | 01:59 PM
mickey's Avatar
you can use a regular coat hanger just make sure that you fold the tip over to a blunt edge so it dont tear threw the insulation on somethign and cause a short.
dougg
Nov 3, 2009 06:15 PM
Jimbo
Sep 7, 2009 10:32 AM
MD MONTE
Aug 29, 2009 11:56 PM
04MonteLS
Jul 13, 2009 10:31 PM
bonang
Oct 26, 2007 09:00 AM
