Replacing radio/stock amp
Old Nov 4, 2009 | 06:20 PM
dirtwing's Avatar
Default Replacing radio/stock amp
I would like to put an aftermarket radio in my '04 Monte and its rated @ 50 watts per channel. Will it work OK running it thru the stock amp or will I have to by pass the amp?
Old Nov 4, 2009 | 07:28 PM
Wilco's Avatar
Does the car has the bose system? Or the regular factory amp? And welcome to the forum.
Old Nov 4, 2009 | 10:33 PM
dirtwing's Avatar
Its a stock (not Bose) system. And thank you for the welcome, wish I'd found this forum a long time ago.
Old Nov 4, 2009 | 11:56 PM
Wilco's Avatar
"its rated @ 50 watts per channel"
For starters your aftermarket HU won't put out more than 17.5 watts per channel so it should be ok as long as you run it straight through the speakers. If you want to use the factory amp you can, but it will need an adapter. For example:
http://www.sonicelectronix.com/item_...+ROEM-UNV.html
You should get in contact with PAC to make sure that this adapter can be used in your car, just to make sure, but in all likelihood it should work. If you have onstar, and you still want it to work, make sure you get assurance from PAC that it will work, or if another adapter will be needed as well.
Old Nov 6, 2009 | 06:34 PM
dirtwing's Avatar
Yea I know its not a true 50 watt stereo but I was hoping I could run it thru the stock amp for a short time. I guess the best way is to patch the speakers at the stock amp when it is bypassed. Does anyone have the wiring codes (wire colors) for this?
Old Nov 7, 2009 | 12:02 AM
04MonteLS's Avatar
Yes, you can use the factory amp still, you just need an OEM integration harness
Hiroska
May 19, 2014 04:23 PM
Murray137
Nov 23, 2013 10:54 PM
Diomenas
Dec 10, 2011 10:30 AM
paintballerr78
Dec 10, 2009 09:40 PM
One Dark SS
Nov 11, 2009 11:34 AM
