Originally Posted by Milhouse
(Post 346117)
If that were the case, and u ran ur remote off that circuit, ur amp would never turn off, right?
If ur using the remote lead on ur deck and still have a crazy loud thump, not good. Ive never had that problem using either the remote lead off the deck or cig circuit. It only does it in the case that I described above. Where the radio is the only thing on like when ive pulled out the key but the radio is on till the door open, But I decide to start the car right from that. It Does it in no other instances at all. |
Which radio harness are you using? Does it do chimes through the RCAs/Amps?
If so, those harnesses typically leave the amp/radio on so it can generate the chimes BBEngineer |
It connected to remote directly out of the HU.. My car doesn't chime since the RCA for my amps are connected directly the the HU as well.
the harness i got for my 02 had a separate box that housed a small speaker just for the door chimes. . . . nothing but music ran through the speakers, door dings and warning lights dings went through the "little black box"
Originally Posted by Jester_20
(Post 346126)
:iagree:
As I stated in my previous post, the remote lead operates the same way as using the cig/aux fuse as a remote lead....it's hot when the key is turned to acc and on yet gets no power when cranking the car then is hot again once the key is released and snaps back to the on position. So if they're the same in that regard then that can't possibly be a reason why it's not good practice to run it from that circuit.
So I guess the only "problem" would be the fact that while the key is in the acc/on position that the amp would be on no matter if the deck was on or not. This was a non-issue to me cause whenever i'm in the car I have my music on. Plus it doesn't hurt anything anyway. The amp being on while the deck is off hurts about as much as the deck being on but the volume turned all the way down. The only real drawback I see would be installer error (allowing the wire to touch a nearby fuse) or not running, securing and terminating the wire properly, allowing a dead short to happen, blowing the fuse it's connected to and causing the other component connected to said fuse to go out too. But if you use common sense and do the install properly there is no way that wire will suffer a dead short in it's lifetime. |
Typically, there is a small delay between when a HU turns on and when it provides power to the amp turn on which will usually take care of the 'crank' issue.
In the hundreds (maybe more) of installs I have done (both on the side and professionally), I have NEVER used an ignition source to turn on an amp... I still completely disagree with you, so I guess we are going to have to agree to disagree... BBEngineer |
After reading both sides, I can see the points of each side. I dont think there is right or wrong way; they each have pros and cons I suppose.
Originally Posted by bbengineer
(Post 346222)
