Most amps also have soft turn on protection to protect it from the turn on thump, audible or not. If the amps sole purpose is to amplify the input signal, how can it be working if the radio is off and its not receiving a signal to amplify? Either way, not working at all or barely working, the difference is like debating if ur home appliances will last longer if u unplug them while ur gone everyday vs. just turning them off, impossible to quantify.
Yep, its only hot when in the acc or on positions as I said above, which is a non-issue given the amps soft turn on protection. But isnt the same true for the decks remote lead? When u turn the key to acc, the deck will come on and in turn turn the amp on bit when u go to crank the car the radio loses power until you release the key back to the on position, right? So whats the difference? |
pink's a constant power source--that's the one everyone said to go off of and after i'd gotten that volt-meter that was the first one i tested. . . .
--you were right though. . . flawless isn't really a good word for it |
Originally Posted by bbengineer
(Post 346087)
The amp is actually working when it's on, it's just not working hard... then when you turn on the radio, you typically get a turn-on thump (even if you can't hear it) which is bad for the amp.
And in other note, I have a 2003 and my cig lighters are always usable even when car is off. |
You sure you have the right one.. I actually posted the wrong pin number... it's pin 6 on Radio C1
Originally Posted by GMSI
Radio C1
6 PK Antenna 14V Switched Supply Voltage
Originally Posted by jaws2008
Is that why like when I turn my car off but the radio is still on until I open the door. And then I decide to start the car again before the 10 min it stays on is over, it does that thump thing; its really loud in my car. I try an remember to open the door before starting in these cases cause I was always afraid it was to loud for the speaker and its annoying.
BBEngineer |
(Post 346111)
Yes, and the exact reason you should use the correct lead to turn on the amp
BBEngineer |
Also, what if your car doesnt have a factory amp, what would you do then?
On both the 00-05 and 06-07, there is an active antenna module that takes a turn on signal from the radio... regardless of whether or not you have an amp
And even you you don't have an amp, the radio still has the turn on wire BBEngineer |
I think when I get a chance I'm gonna re-try that pink guy. . . . I don't think it worked the last time but after 5+ people saying that's the one to use, it's worth trying again. . . . . if I get to it tonight I'll post something. It'd be a he** of a lot easier than doing what i did. . . . Thanks for the suggestion and i really hope it works.
No problem... if it doesn't work, let me know and I'll see what I can come up with
BBEngineer |
(Post 346109)
And in other note, I have a 2003 and my cig lighters are always usable even when car is off. If ur using the remote lead on ur deck and still have a crazy loud thump, not good. Ive never had that problem using either the remote lead off the deck or cig circuit. |
