Remote Start
Old Aug 31, 2012 | 06:55 PM
Carlo8686's Avatar
Default Remote Start
When i bought my 05 MC it came with a keypad for remote start and keyless entry to doors and trunk.
I live right by a Highschool and in a neighborhood. Twice now id go out side and my cars running, My keys are hanging so i know buttn was never pressed. Is this cause someone else has same keypad on same channel or is it a short in the remote start system causing it to just start up.
Im not too worried as it does shut off after lik 10-15 mins.
Old Aug 31, 2012 | 08:27 PM
Mike 00LS's Avatar
I'd say it's a glitch within the remote start itself, causing it to start. The remote starts have to be programmed to fool the car into thinking your key is what started the car, so it's not someone else with the same frequency.
Old Aug 31, 2012 | 08:28 PM
Carlo8686's Avatar
Is there a way to like power down the remote start to restart it.
Old Aug 31, 2012 | 08:34 PM
Mike 00LS's Avatar
Pull the plug on the module - where that is, all depends on who installed it. Mine is under the dash on the drivers side. But if it's a bad module, the only way to fix it is to either replace it or just disconnect it and don't use it anymore.
YOU COULD TRY:
Opening the drivers door...turn the ignition key to on position(dont start the car) and then turn the key off (remove it)and then close the door lock and reset the alarm...and wait 30 secs...then try the auto start...
Thats how some of the after market alarms are reset...
Maybe the batterys lo in the key fob?
Old Aug 31, 2012 | 08:36 PM
Carlo8686's Avatar
Ill try both ways and see.
Old Sep 5, 2012 | 11:18 PM
NovaSS369's Avatar
Is it a DEI or Viper Product? Look under the drivers side dash and see if you can locate the brain.
Old Sep 26, 2012 | 05:47 AM
Justin_Z's Avatar
How much do trust your remote alarm system? I think, you must be aware of hacking activity. Most people think remote start and remote keyless entry devices are safe. Think again, because they are simpler to get around than most would realize. It's been confirmed several times, by both car thieves and experts searching for security gaps that it's much easier to get into than some people realize.
Old Oct 24, 2012 | 01:27 AM
2004 monte carlo's Avatar
I have an 04 Monte soon to install alarm. Am I goin to need a bypass module? I know most cars need it when the key has a chip.
99monteal
May 30, 2007 10:14 PM
dogmanx
Feb 7, 2007 03:35 PM
dogmanx
Feb 6, 2007 05:25 AM
duvalrattler
Jan 5, 2007 10:10 AM
AFAN4_29
Jan 4, 2007 12:05 AM
