Remote Positive Terminal
What year car? If you have a 5th gen- look at how small the wire is connecting the positive to the remote terminal- and IIRC that's already feeding other stuff. So IMO you're better off just getting an aftermarket GM sidepost adapter and connecting your amp properly to the battery directly.
Not adviseable. Reason being is you might as well run the same tiny gauge wire that is run from that terminal to the battery cause that's all the current you'll be able to carry across your amp power wire.
Why are you wanting to do that? That remote terminal is just a couple feet from the battery itself.
gerolf
May 22, 2015 12:22 PM
