6th Gen ('00-'05): Rearview Mirror problem
I have an 04 ls that has a rear view mirror problem. It has the dimmer built into the mirror that makes headlights behind you not as bright. For some reason it will not stay on when it is supposed to be on. You can move the wires connected to the mirror to make it come back on so I assume some of the wires are loose. What would be the best way to tighten the wires up so that feature will work on a more consistent basis?
Thanks in advance
(I do not have onstar in this mirror if it matters)
Thanks in advance
Repair Guide: How to change rearview mirror lights - 6th Gen
ChibiBlackSheep
FWD Tech Guides '95-'07
31
Sep 3, 2015 01:49 AM
