rear 6*9 speaker removal
Old Dec 31, 2008 | 09:24 AM
sthurs's Avatar
Default rear 6*9 speaker removal
I'm trying to replace the 6*9's in the rear of my Carlo, and have no clue where to begin. I have a 2006 LS, and If I knew where the screws to remvoe the rear deck where,or how to remove the rear seats, I could get this completed.
Can someone help me out with this?
Old Dec 31, 2008 | 06:14 PM
MonteTank's Avatar
Default RE: rear 6*9 speaker removal
well i know how to do it for the 00-05 but idk if its the same for the 06-07
but first you need to fold down the rear seats, then theres a plastic piece connected to the rear deck with four bolts. remove the bolts and yo can pull the plastic piece/ends of back seats down so you have more access to the rear deck.
THEN, you hav to pull out the board/felt material in the rear deck.... you will have to pull out about 3 plastic clips by wher you removed the bolts earlier to get it out.
once out you have visible acces to the speakers. now you need to remove the four screws holding each speaker in place, cut the wires, lay in the new speakers and wire them...
the just but the rear deck piece back in and put in the four bolts and you should be good.
hope this helps; not so detailed but its somethin
Old Jan 2, 2009 | 10:51 AM
sonin66's Avatar
here is whatanother wrote abouta complete install of the 6x9'shttps://montecarloforum.com/m_40423/tm.htm
Monte SSV
Dec 13, 2008 03:16 PM
onlyonetaz
Aug 7, 2008 03:33 PM
04MonteLS
Jun 18, 2007 06:01 AM
paudemge
Apr 27, 2007 01:54 AM
LwCwb
Dec 26, 2006 01:07 AM
