6th Gen ('00-'05): radio swap
Old May 5, 2013 | 10:17 AM
ssdriver's Avatar
Default radio swap
My 05 Monte has a factory AM/FM, cassette radio, I would like to replace it with a factory AM/FM cassette/CD unit. My question is will an unlocked unit still allow me to use the function programs in the radio, like turning off warning reminders and other settings. I hope this is clear.
Ebay has couple of nice unlocked units, plug & play.
Old May 5, 2013 | 10:49 AM
RonBoySS's Avatar
You can use other methods to turn off the reminders, use the headlight and or gas pedal method. Give you a choice to use an aftermarket, can get better for less sometimes that route.
Old May 5, 2013 | 02:08 PM
When looking for radios in the '00+ Montes, I am not sure there is a such a thing as "unlocked". I think no matter what it needs to be programmed for your car with a GM TechII scan tool.
I replaced my factory CD player for an MP3 factory CD player from a Venture Van/Cavalier (a radio GM says is "not supported" for my car, as a result I went through a fair amount of education). I had a guy dial it in with a GM Tech II and it works great.
FYI - Don't get hooked into the concept "You can unlock it by pushing these buttons and calling this GM number and getting an unlock code". That is valid for Pre-2000 Montes (the TheftLoc system was changed in 2000, TechII is the only way to unlock it).
guysnydr
Sep 18, 2013 07:43 PM
dustybird3
Apr 8, 2011 10:10 PM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
jackjeckel757
Jan 8, 2010 07:09 PM
White05LT
Apr 24, 2007 02:36 AM
