Program Factory Remotes
I have tried a few different methods I have found on this forum and a few others with no luck. I am looking for a way to program a new Keyless entry remote on my 04 Monte Carlo SS with an aftermarket headunit. Is there a surefire way to do it or am I either going to have to goto the dealer or put the factory radio back in the car?
I took mine back to the Chevrolet dealership from where I bought my car this past summer to have 2 fobs I bought off of eBay programmed, $50 for the 1st and $15 more for the 2nd . So I thought that was a good enough price.
Jason, unfortunately you can't self program a fob without the factory radio, a Tech 2 scanner or a key programming tool. Many lock shops can do it too.
Zippy, congratulations on having a dealer that is more fair than most. Years ago a dealer near me charged $120 just for the programming, another $75 for the fob. I suppose there are a few honest dealers out there, but this is one of the primary reasons I decided to buy my own Tech 2 and factory service manual and do everything myself. The Tech 2 has paid for itself many times over.
So I swapped in my OEM headunit for a bit and programmed my new remote however it does exactly like the old remote that I thought was failing due to taking a unexpected drink. Basically sometimes it will lock/unlock my car sometimes it wont. Sometimes I have to be right on top of the car sometimes I can be a little bit away. Any ideas as to what is going on with it?
If ALL functions are weak, the receiver is not the problem. The receiver is just for the door locks. You mentioned you need to have the BCM programmed. If you're having a problem with the BCM, it or the wire connections to it could be the culprit since it's the "brain" for the keyless entry system. If it or the receiver get replaced all fobs need to be reprogrammed with a Tech 2.
I was suspecting a faulty BCM as I was having passlock issues, but replaced the keyswitch first and that took care of it. I do have a new AC Delco BCM that is just sitting in the backseat, but I don't seem to be having any issues anymore with the current BCM other than the current state of my remotes.
