problem with foglamps
Old Aug 12, 2010 | 10:48 PM
mcdave01's Avatar
Default problem with foglamps
well i found my first problem with the monte, i went to test my foglamps and they don't work. i checked the bulbs and fuses and they are all fine, im thinking its the actual switch on the dash because it doesnt seem to even engage it just pushes in but never engages. has any one else ever had this problem?
Old Feb 21, 2011 | 07:36 PM
Justinnnn's Avatar
I've never head of such but I'm trying to install foglights myself and I hope this doesn't happen to me. Could someone please tell me the dimensions of the OEM fog lights? I have a 2003 Monte and was looking to buy aftermarket fog lamps but I don't know what size would fit perfectly. If someone could direct me to the aftermarket fog lamps they bought they would be great to. Thanks.
Old Feb 21, 2011 | 07:39 PM
KJRich's Avatar
The foglight switch doesn't really "engage" or click into an "on" position. You press it and it returns to its original position, with a small light on the button itself indicating the fog lights are on. I suppose the switch could still be bad, though.
Old Feb 21, 2011 | 08:23 PM
if your looking to replace it i have a like new switch. i would make sure all connections are good including the one behind the switch itself. is your monte an ls or ss
Old Feb 21, 2011 | 09:47 PM
mcdave01's Avatar
problem has been fixed a while ago i just forgot to post an update, i replaced the switch, bulbs, fuses, relays, everything i can think of. so i finally took it to my local gm shop and they fixed it, there was supposedly a short in the pcm so they had to replace the whole thing, costed $480 which im not happy about but atleast it is fixed now.
Old Feb 21, 2011 | 09:51 PM
KJRich's Avatar
My bad, I didn't look at the dates on the posts, but thanks for the update!
Old Feb 21, 2011 | 10:33 PM
wow sorry i didnt check the date either ahah glad you fixed it
Old Feb 23, 2011 | 06:41 PM
RaeRaeAlmighty's Avatar
http://www.autozone.com/autozone/acc...er=618333_0_0_
^the one's I have. Had to make a special bracket to attach them to the car, but I love em!
Justin Myers
Sep 19, 2012 08:23 PM
inyanalili
Apr 2, 2012 08:31 AM
