Problem fitting pioneer headunit into dash. 2004 monte
Old Dec 19, 2010 | 11:07 PM
rmase182ls's Avatar
Default Problem fitting pioneer headunit into dash. 2004 monte
i bought a single DIN pioneer mvh 8100bt headunit for my 04 monte. i wire everything up thinking im done. I go to place my dash back on and i relize the hole in the dash isnt big enough! on crutchfield it says it would fit my car which it does but the headunit is too wide and doesnt have enough clearance by about a couple cenimeters. Any tips on what to do?
Old Dec 19, 2010 | 11:43 PM
jaws2008's Avatar
GOT SPL
Did you have it in the vehicle specified dash kit
Old Dec 20, 2010 | 12:46 AM
do you have any pics? if you got the vehicle specific one it should fit fine, here's the one:
http://www.crutchfield.com/p_1209920...t.html?tp=3121
Old Dec 20, 2010 | 11:42 AM
rmase182ls's Avatar
Yes i do have that. it fits in the dash kit and botls up perfectly. but that big long peice of dash that you have to take off to reach the radio...that it what is too small.
Old Dec 20, 2010 | 12:13 PM
jaws2008's Avatar
GOT SPL
The hole were the radio goes in. there is no way it should be for a single din. do you have pics.. Im kinda confused to.
Are you sure you snapped the dash back in properly all the way and didn't miss any snap in pins. make sure to get the one below the HVAC controls and above the Head Unit area and around the Hazard button.. and dont forget to connect the hazard button. to push the pins in just give it a mild slam around the those areas. That dash piece should touch the HVAC control area, should be NO gap
Missing some of those pins will not align the dash correctly and so the hole will not be centered correctly so it may appear that its to small when it is not.
Old Dec 20, 2010 | 12:29 PM
rmase182ls's Avatar
Jaws you were right. i checked and some pins were missing
Old Dec 20, 2010 | 12:32 PM
jaws2008's Avatar
GOT SPL
lol. Ya way back when When I put in my first one in the monte I had almost the similar issue and ive always made sure Ive snapped them in all the way since..
Josh_NGR
Mar 21, 2012 08:56 PM
M-pow-pow
Apr 11, 2011 09:59 PM
eviling
17
Dec 5, 2010 05:03 PM
steven789
Aug 25, 2007 10:21 PM
lucyzoc
Aug 18, 2007 09:34 AM
