Please help lights went nuts
Old Jun 11, 2012 | 06:06 PM
butch049's Avatar
Default Please help lights went nuts
Had battery removed today now the lights arent working right no turn signels parking lights stay on high light not working light comes on hazerd light on dash on but dont blink wont go off Can you help thanks Butch and Heartbeat.
Old Jun 11, 2012 | 07:25 PM
03SSLE's Avatar
Why was the battery disconnected? Did you do any work or repairs to the car while it was?
Old Jun 11, 2012 | 07:37 PM
butch049's Avatar
yes had battery tray painted. now turn on blinkers both come on when turned on left or right
Old Jun 11, 2012 | 07:41 PM
butch049's Avatar
also they blink fast
Old Jun 11, 2012 | 07:51 PM
djtiny's Avatar
Is it just your lighting system? Or all of the electrical? (Check HVAC, Radio, etc)
When you disconnected the battery did you take the negative off first?
Do you have the negative and positive hooked up to the correct terminals right now?
Old Jun 11, 2012 | 08:03 PM
butch049's Avatar
I didnt do so i dont know radio seems to work terminals are ok some work the lights go on
Old Jun 11, 2012 | 08:18 PM
Mike 00LS's Avatar
This would be so much easier if this wasn't all run-on sentences with no capitalization and punctuation.
So the lights are your only problems? Do the low beams work? If the battery fried something I would think you'd be having interior electrical problems, too.
Your problems could be unrelated to the battery. The multi-function switch and hazard relay could be shot, meaning no turn signals or hazards as well as no high beams.
Screwing the battery up can screw up your BCM, which would explain the electrical problems, but as I said, there would be more problems then just the exterior lights.
Old Jun 12, 2012 | 06:27 AM
butch049's Avatar
Got in car this morning everything worked . Does it have to reset after battery is disconnet? Strange! Thanks for help sorry about running things together I was in a hurry. Butch
Old Jun 12, 2012 | 06:48 PM
butch049's Avatar
Found the problem they left a ground wire loose if you ever have that problem.Thanks for the help.
nlewis44
Dec 15, 2010 07:57 PM
YBnormal
Jan 2, 2009 03:32 PM
c54u
Feb 18, 2008 06:18 PM
JTyler
Aug 19, 2007 09:03 AM
HyperFox
Jul 27, 2007 10:00 PM
