passanger low beam issue!!!!!!!
Old Jan 31, 2012 | 12:17 PM
monte003's Avatar
Default passanger low beam issue!!!!!!!
hey guys it started after i flushed my radiator my hids started flickering then would shut off while driving so i looked at the ballast and water was dripping out of it so i unplugged it and the stock connecter and the ballast where they connect is rusty but then i replaced my blown headlight fuse and they went out again except now it wont come on at all. any help would be appreciated thanks
Old Jan 31, 2012 | 12:19 PM
monte003's Avatar
also i cleaned the connector and opened the ballast up and it looked fine in there
there was water coming out of the ballast? you may have a bad ballast now, can you get the rust off the connector? it may not be making a secure connection.
where is your ballast mounted that it got that wet?
bcsfd306
Jan 12, 2019 07:58 PM
Zod642
41
Jan 27, 2018 09:56 PM
BlackWidowSS
Dec 18, 2014 03:55 PM
Aaronb425
Dec 29, 2012 09:10 AM
blownratc10
18
Feb 2, 2012 06:24 PM
