new stereo install power wire
I have just started my search for a hole in my firewall to pass a power wire thru for some new stereo eqpt. Has anybody had any luck with using a pre existing hole or have you had to drill a new pass thru?... i am trying to do this install with out drilling...
Thanks for feedback... |
I ran mine threw the fender & cut a slit in the rubber boot that the door wires go threw & ran it inside the car
Wow... Thats a wicked idea!.. thanks for the help!
What size power wire did you run?... how much are you powering? |
I'd try to go through the boot in the firewall.
You can drill in it, just make sure you're not hitting anything on the other side, I wouldn't go through the fender personally just because I didn't like seeing the wire there everytime I opened the door, but it's up to you. I've gone under the grommet and it fit fine for me. How To Run Sub Wires in 00-05 Monte Carlo-red04montels - YouTube |
wow bad ideas abound, never compromise seals. theirs a perfectly good, perfectly and nealry unused rubber gasket in the passenger and driver side firewall foot panel area.
http://img203.imageshack.us/img203/4320/img0994ia.jpg http://img189.imageshack.us/img189/4654/img1165j.jpg |
Thanks everybody for your input...
was the unused gasket in the foot areas pretty easy to get to? and what size wire did you use there? that looks pretty substantial... |
its not hard to get to just pulll the carpet back a little and move the seat all the way back. so its not in your way. that wire looks like 0 gauge. i ran 0 through mine no problem.
