New speakers = Door panel rattle / buzz / vibrating
Old Apr 12, 2013 | 10:34 AM
milrlyt's Avatar
I've dealt with this for a long time lol. Here's some pics of what I had to do (granted, I had way more powerful midbass in there so the rattles were worse.)
Also note, chopping off the chunk of plastic that sticks out around the speaker on the panel will help a bit.
Peel and stick ensolite under the plastic pins. This helped IMMENSELY.
Deadener on the creaky plastic panel.
And deadener on the door itself.
You will probably need less than I did, but it's just an idea of what you might need.
Old Apr 12, 2013 | 04:37 PM
tps221's Avatar
lol i have stock speakers that rattle them but then again i have a sony headunit the worst rattle in mine was that back panel and where it hits the rear window thank you sony 6x9's and kicker 10's
Old Apr 28, 2013 | 09:21 AM
owens91's Avatar
if u got bigger speakers then the panel is possibly hitting the speaker...im having this problem myself and im looking for a dremel to shave off the piece thats in the way
Old Nov 28, 2016 | 11:00 AM
proraver's Avatar
You are having a problem with resonance. Now it's time to start shimming and isolating parts of the door panel to determine where the rattle is and remove it. Start by finding a track that consistently causes the vibration and gently press on the door panel to find the vibration. Once you find the area where it is vibrating make sure all the door panel clips are properly seated in the door panel and fully engaged into the door itself. Tiny shims of cardboard around the edge of the panel will help you eliminate the buzz in most cases.
cmamtm
Oct 22, 2016 10:05 AM
LilSeanCB
Aug 4, 2013 04:30 PM
joeykl66
Sep 11, 2012 12:02 AM
ChevyWhirlwind
Mar 22, 2012 12:22 AM
prez
Dec 29, 2006 06:55 PM
